Baaaaaaaaaaad sounds under load
Hey all.
I was at a stoplight tonight and dropped the clutch with high revs. There was a clunking/grinding sound with some slipping. If I accelerate VERY slowly, the sound goes away. But as soon as I give it any gas it makes the same horrible noise.
I pulled the primary cover and adjusted the clutch and it made no difference. I have fondled motor internals before, but am not so experienced with trannies. Any help would be appreciated! Oh, it's a 2007 softail custom with about 40k miles.
I get the feeling this is going to be a 12-15 beer fix...
trans pulley splines stripping, cutch hub splines stripping or the compensator either loose or really bad. could be the trans main shaft bearing getting bad, when mine went it made a clunk,clunk,clunk noise when taking off and i could feel it. getthe bike up in the air and roll the back wheel to see if you can tell where it's coming from. the more tension i put on my pulley the louder the sound. time for a tear down it sounding like. good luck with it.
I will be pulling the clutch shortly... Heading out to get a socket to fit that nut.
Harley mother ship got tired of all the in warranty major repairs and put the cush rubber drive on the rear drive pulley on the big boys now. Even they drive like being on a Sportbike now.
If it drives and sounds Ok driving it like it was designed to do, nothing is probably broke yet.
If this happens, it could cost you 4K or so....This is CHarley's 4th gear and he swears he only drive like a little old gray hair grandma on Sunday.
Unfortunately it doesn't sound and drive ok. If I give it more than about 10% it starts to slip and grind. The sound is like a chainsaw on a steel handrail. That's the only way I can describe it. There were many times when I would hear the KLUNK of the compensator reaching it's limit. But it was always just one klunk. It almost sounds like it is in gear when you are really light on the throttle, but then gears or splines or something is grinding if you give it any throttle at all. It's a diabolical sound. I'm wishing I had recorded it to share.
