Final Drive Pulley Q
Hi, my final drive pulley is coming apart a bit so I'm looking to replace it. It's a 1996 FXDS, so I think that's a 70 tooth and 1 1/2" wide? Is there a way to convert it to the skinnier later style belts? Will this buy me real estate so I can put on a larger rear tire?
Thanks a lot.
Thanks a lot.
Also, did you have to swap the front pulley? Or just belt and rear pulley?
Thanks a lot.
40000001 BELT,DRIVE,24MM,133 TOOTH
40000008 SECONDARY BELT,166T,25MM WIDE,POLY
40000013 BELT,SEC DRV,RR,131T,20MM WIDE
40001-85 REAR BELT, 136T
40003-79 SECONDARY BELT
40010-89 REAR BELT, 127T
40012-90 REAR BELT, 128T
40015-00B SECONDARY BELT,RR/133T,1.12 WIDE
40015-90 REAR BELT, 133T
40017-94 REAR BELT, 130T
40022-91 SECONDARY BELT, XL, 128T
40023-86 REAR BELT, 132T
40024-04B SECONDARY BELT,RR/139T
40024-07 BELT, SECONDARY DRIVE, 137T, 1 INCH WID
40024-09 BELT, SEC DRIVE, 140/24MM
40024-97 REAR BELT, 139T
40027-01C BELT,SECONDARY ,150T
40038-91 REAR BELT, 125T
40040-05 BELT, REAR DRIVE, 139 TOOTH
40046-07 BELT, SECONDARY DRIVE, 131T, 1 INCH WIDE
40048-07 BELT, SECONDARY DRIVE, 130T, 1 INCH WIDE
40056-07 BELT, SECONDARY DRIVE, 136T, 1 INCH WIDE
40058-07 BELT, SECONDARY DRIVE, RR 133T,1 IN WIDE
40059-09A BELT,RR/SEC DRV/132T,24MM WIDE
40073-07 BELT, DRIVE, REAR, 133T, 20MM WIDE
40074-07 BELT, DRIVE, REAR, 132T, 20MM, JAPAN
40105-04B BELT SECONDARY ,149T
40118-05 BELT, SECONDARY DRIVE, 149 TOOTH
40119-05 BELT, SECONDARY DRIVE, 150 TOOTH
40130-03 REAR BELT, 139T, HEAVY DUTY
40130-03A BELTDRIVE,RR/139T
40144-07 BELT, SECONDARY DRIVE, 151T, 1 INCH WIDE
40145-07 BELT, SECONDARY DRIVE, 152T, 1 INCH WIDE
40307-00B SECONDARY BELT,RR/135T,1.12 WIDE
40371-07 BELT, SECONDARY DRIVE, 136T, 1 INCH WID
40570-04B BELT, SEC, 136T
40571-04B SECONDARY BELT, 137T/1.125
40591-07 BELT, SECONDARY DRIVE, 137T, 1 INCH WID
40594-06A SECONDARY BELT,RR/132T,1.12 WIDE
40627-06 REAR BELT, 149 tooth, 21MM
40655-06 BELT, SECONDARY DRIVE, 135T
40658-06 REAR BELT, 150 tooth, 21MM
Jumpman
08-23-2013 09:13 AM
