Primary/Transmission/Driveline/Clutch Find answers to general powertrain, primary and transmission. Have clutch issues and need suggestions? Post them here.
Low Oil Level in Primary, FLSTC 1999 Evo
Old 09-08-2015, 07:14 PM
Kayakeur's Avatar
Kayakeur
Kayakeur is offline
Location: Eastern foothills of Shenandoah Mountains, Virginia
Default Low Oil Level in Primary, FLSTC 1999 Evo
Oil Level Very Low in Primary, 99 FLSTC Heritage Classic
Oil level does not come up to book level. Concerned, puZzled.
I just changed the oil in Primary. (First time, just-purchased 41k miles)
Drained 29 ounces, measured, dark gray used.
Added 27-28 ounces new Chevron dino 10w40,
I added the oil into the Chain Inspection opening Fig. 1-3 page 1-42.
New Oil Level Far Below recommended.
Manual says page 1-42 item 6: . . level w bottom edge clutch diaphragm spring, Fig 1-6, page 1-43, 26 ounces.
Oil level is far below that. I can just see oil surface far below.
No leaks. Bike upright on lift, level fore-to-aft. I said my prayers and rode it 20 miles afterward, checked level again, same low.
Manual says over-fill “may cause rough clutch engagement, incomplete disengagement, clutch drag and/or difficulty in finding neutral at engine idle.”
Accckkkk! What The Hell??
Old 09-09-2015, 07:55 AM
grbrown's Avatar
grbrown
grbrown is offline
Received 2,851 Likes on 2,419 Posts
Yours is a common query, the quantities of oil given in the manual are for guidance only, don't follow them blindly. Fill to the level described, in this case that "bottom edge clutch diaphragm spring". It takes whatever it takes! Don't be puzzled - ride and enjoy!
Old 09-09-2015, 10:48 AM
qtrracer's Avatar
qtrracer
qtrracer is offline
I think it might say "no higher than the clutch diaphragm spring" and "oil visible in the primary chaincase" So put 2 more ounces in and see.
Old 09-09-2015, 11:28 AM
fxstc1999's Avatar
fxstc1999
fxstc1999 is offline
Remove derby cover and add primary oil (not primary chain inspection cover). You'll have a much better view of the clutch.
Old 09-13-2015, 03:25 AM
Kayakeur's Avatar
Kayakeur
Kayakeur is offline
Thanks, all. I drained the temp oil I put in the primary 20 miles ago just to flush out any remaining old stuff, and put in exactly a quart of Valvoline Dexron III / Mercon dinosaur ATF, repeatedly recommended elsewhere on HDForiums. Nice level, 3/16 inch up on the largest disc.
In two days (9-14-15) I leave Virginia on ten day ride to Georgia and random places between. Cheers.
Old 09-13-2015, 09:03 AM
smitty901's Avatar
smitty901
smitty901 is online now
Received 9,555 Likes on 5,152 Posts
Here you go you can't go wrong bike level. It may get a lot of press but ATF don't belong in there Take it people that really ride their bike.
Primary in that EVO F+ if you want it to last.
If you are new to EVO also look up clean Tappet oil screen.
Attached Thumbnails Low Oil Level in Primary, FLSTC 1999 Evo-primary-fluid-level_.png
Old 12-31-2015, 12:04 PM
Klaatu77FLH's Avatar
Klaatu77FLH
Klaatu77FLH is offline
Does the bike need to be completely upright or on the kick stand for proper oil level?
Kayakeur
EVO
20
09-10-2015 07:24 AM
hdchaplain
04-25-2015 09:56 AM
mikeo33y
09-02-2014 01:13 PM
rookie racer
05-20-2010 07:18 AM
DAVEY
Oil Archive (no new posts)
05-02-2007 10:12 AM
Quick Reply: Low Oil Level in Primary, FLSTC 1999 Evo
