Primary/Transmission/Driveline/Clutch Find answers to general powertrain, primary and transmission. Have clutch issues and need suggestions? Post them here.
Leaking clutch cable
Old 09-09-2015, 07:38 PM
tmartinez1981's Avatar
tmartinez1981
tmartinez1981 is offline
Stage I
Default Leaking clutch cable
Hey all, I've got a 03 Road King Classic with just over 15k miles. I have a stainless cables and recently i noticed oil spatter all over my horn cover, primary, exhaust and bag after a long road trip. Closer inspection revealed oil leaking under the dust boot on the clutch cable. I have no idea if the whole cables bad or if there's an o-ring that needs replacing? I'm not exactly sure how you take it apart to look for the issue either. I'd like to try and fix this myself, but I'm afraid I may have to bring it in. Any tips would be greatly appreciated!
Thanks!
Old 09-10-2015, 07:44 AM
corliss@bakerdrivetrain.com's Avatar
corliss@bakerdrivetrain.com is offline
Received 1,856 Likes on 1,287 Posts
There should be an o-ring where the cable goes into the transmission side cover.
Old 09-10-2015, 07:45 PM
DanDman's Avatar
DanDman
DanDman is offline
Check if the tranny is over filled, also the adjustment part of the cable should be vertical. A bad/missing o-ring would leak at the transmission cover were the cable enters.
Old 09-10-2015, 07:52 PM
Jackie Paper's Avatar
Jackie Paper
Jackie Paper is offline
Received 4,528 Likes on 3,781 Posts
On my Softail, long while back when it had a maintenance on it, the dealer must have dumped a lot of oil when doing the filter. He cleaned up but failed to get the oil out of the extra cover like shield on cable. It gave the impression it was leaking at the transmission for quite a while. I slid it fwd a little and discovered the wind was pushing it back. Little liquid detergent poured into it and a little spray from water hose finally flushed it out.
JuanderBoy
10-30-2019 11:23 AM
dyoungblood357
09-01-2017 08:01 AM
wideglideCVO
Engine Mechanical Topics
17
08-11-2016 10:31 PM
dickey
06-09-2012 06:05 AM
daharleyrdr
08-17-2009 09:14 AM
Quick Reply: Leaking clutch cable
