Primary/Transmission/Driveline/Clutch Find answers to general powertrain, primary and transmission. Have clutch issues and need suggestions? Post them here.
Lock up clutch
Old 09-11-2015, 04:05 PM
2k2ss's Avatar
2k2ss
2k2ss is offline
Default Lock up clutch
Does a lockup clutch increase the holding power at low rpms or just higher rpm?
Old 09-11-2015, 05:18 PM
OldEnuf2NoBtr's Avatar
OldEnuf2NoBtr
OldEnuf2NoBtr is offline
Received 1,811 Likes on 1,064 Posts
Using the principles of centrifugal weight, its ability increases in the upper RPM limits. That's why top-fuel dragsters run a similar set-up.
Old 09-12-2015, 11:51 PM
Next In Line's Avatar
Next In Line
Next In Line is offline
Depends on the springs and weights.
From Barnett Clutches:
It starts working about 2200 RPM. As the revs go up the harder it squeezes.
If you run stiffer springs it will still come on at the same time but the stiffer springs will work better with a high horse power engine.Heavier weights will make it come on earlier but we do not offer any. You can machine them down to be lighter but wont lock up till higher in the engines.
Chopperbob
05-30-2012 09:29 PM
Govno
01-18-2012 07:45 PM
Jackie Paper
09-18-2010 05:49 PM
TRacer
08-05-2010 03:59 PM
bradrosewood
07-11-2010 08:19 PM
Quick Reply: Lock up clutch
