Primary/Transmission/Driveline/Clutch Find answers to general powertrain, primary and transmission. Have clutch issues and need suggestions? Post them here.
Chain upgrade from belt
Old 10-06-2015, 05:41 PM
98hotrodfatboy's Avatar
98hotrodfatboy
98hotrodfatboy is offline
Received 4,793 Likes on 3,304 Posts
Default Chain upgrade from belt
Hey all , never had a chain drive Harley before but it was time to upgrade from the belt. Broke two belts this year. I done see any one making a strong enough 1" belt. So I went to a chain. It's a 530 chain with PBI sprockets.
How much slack should there be new and when broken in?
When the chain is at rest the bottom of the chain has a 1/4" of sag and when i push firmly up on the top as noted in the pics I get 3/4" travel. Is this enough for break in? And what should it be when broke in?
Thanx Bob....
Sorry it comes out upside down my phone camera is screwed up....
Attached Thumbnails Chain upgrade from belt-20151006_182749.jpg   Chain upgrade from belt-20151006_182817.jpg
Old 10-07-2015, 08:31 AM
corliss@bakerdrivetrain.com's Avatar
corliss@bakerdrivetrain.com is offline
Received 1,856 Likes on 1,287 Posts
I always tell people just like with a belt 5/8 to 7/8 free play.
Old 10-07-2015, 09:17 AM
grbrown's Avatar
grbrown
grbrown is offline
Received 2,851 Likes on 2,419 Posts
Even when new your chain is likely to have a tight spot and a slack spot. Rotate it until you find the tight spot and set tension there.
Old 10-07-2015, 12:16 PM
98hotrodfatboy
K Thanx, should finally be on the road again by this weekend.
Old 10-12-2015, 08:25 PM
98hotrodfatboy
Default Update on the switch to chain
I rode a lot this past weekend, about 300 miles and man it felt great. Haven't been on the road in a good 5 weeks due to repairs and upgrades to the drivetrain.
I gotta be honest and say that all my worries are gone with belt failures. I can't believe how quiet this chain is. Got the kit from Zippers and love it. Trans gear is a 23 and rear sprocket is a 49.
Matched that to my new belt primary drive from Baker making my overall ratio a 3.27. Awesome power transfer and great cruising in 6th gear @70 mph/ 2650 rpm. exactly what I was looking for. I'm finally getting my bike to where I want it....
Old 10-13-2015, 05:53 AM
Next In Line's Avatar
Next In Line
Next In Line is offline
Don't you have to remove the inner primary every time the chain & sprocket is worn?
Old 10-13-2015, 12:37 PM
98hotrodfatboy
Chain no.. Front sprocket yes but if you get a well made sprocket you won't have to worry about it. Probably would outlast the stock chain and sprockets that HD uses in the primary. The rear, That's another story but PBI makes good ****.
VoiceofReason44
09-16-2017 12:16 PM
bass3167
06-15-2010 08:11 AM
laecutter
05-14-2008 07:09 PM
abcd9906
04-01-2008 01:59 AM
HOTLAP
04-15-2007 11:38 PM
Quick Reply: Chain upgrade from belt
