Primary/Transmission/Driveline/Clutch Find answers to general powertrain, primary and transmission. Have clutch issues and need suggestions? Post them here.
stripping trans to powder coat
Old 11-25-2015, 05:34 PM
filthpig's Avatar
filthpig
filthpig is offline
Default stripping trans to powder coat
I want to strip down my 6-speed to powder coat.
The gear set slides out when bolts are removed from the trap door?
The main gear bearing will need to be pressed in to remove?
Shifter pawl should come out by pressing into housing?
It seems to be pretty straight forward am I missing anything?
No special tools?
thanks,
filth
Old 11-25-2015, 05:58 PM
filthpig's Avatar
filthpig
filthpig is offline
I ask, because previously, I bought a broke tranny and paid the dealer to put gears into new tranny case, it was expensive.
I kept my original grey tranny and want to do a dark blue powder coat instead of the factory black.
Old 11-26-2015, 04:54 AM
grbrown's Avatar
grbrown
grbrown is offline
Received 2,852 Likes on 2,419 Posts
I'm paying someone to strip and rebuild my tranny at present, although not to paint it! I regard that task as way outside my comfort level. Yes you will need a few special tools, to assist dismantling and rebuild. It's a lengthy process which you really should get a factory service manual to learn, which spells out everything in detail including tooling used. You may also find useful videos on-line, but the book should be your starting point.
Old 11-26-2015, 03:02 PM
qtrracer's Avatar
qtrracer
qtrracer is offline
Show bike?
Old 11-26-2015, 05:55 PM
filthpig's Avatar
filthpig
filthpig is offline
I have a manual........thought perhaps someone with actual experience of transmission disassembly might chime in. I simply want to pull guts out, wrap in clean towel, set aside to be reassembled after coating case.
no not a show bike, just my OCD..........
I have a s&s 124 hot kit, want to build motor after powder coating cases, thought I would do tranny case as well. The matching set would be my twist.
Old 11-27-2015, 04:57 AM
grbrown's Avatar
grbrown
grbrown is offline
Talking
Hopefully someone with firsthand experience will call by soon! The engine should look good in a matching paint job. We'll need to see photos of the finished bike of course! Jus' sayin'!
rauchman
Powdercoat & Paint
09-28-2015 05:22 PM
2012SuperGlider
Powdercoat & Paint
03-23-2013 12:11 PM
45js45
Powdercoat & Paint
04-12-2012 11:54 AM
Slightedge
Powdercoat & Paint
04-15-2011 05:44 PM
boston_jake01
General Topics/Tech Tips
11-08-2006 10:40 AM
Quick Reply: stripping trans to powder coat
