Primary/Transmission/Driveline/Clutch Find answers to general powertrain, primary and transmission. Have clutch issues and need suggestions? Post them here.
Trans locks up in 1st and 2nd
Old 02-07-2016, 04:43 PM
customsoftail200's Avatar
customsoftail200
customsoftail200 is offline
Default Trans locks up in 1st and 2nd
99 Dyna. Just put this trans back together and testing it out by spinning shaft by hand it locks up in 1st and 2nd gear, 3-5 are fine. I took it back apart inspected all the gears and snap rings all are in correct place. Put back together as per manual same thing. I've done these many times before but never had this happen. Has anyone run into this before?
Old 02-08-2016, 01:58 PM
corliss@bakerdrivetrain.com's Avatar
corliss@bakerdrivetrain.com is offline
Received 1,856 Likes on 1,287 Posts
Double check the shifter pawl adjustment.
Old 02-08-2016, 06:07 PM
customsoftail200
Just double checked pawl, it was just a hair off but it didn't change anything. I went to put the sprocket on and had very little threads. Found the main drive gear wasn't all the way in. Works great now!
Ccr71
04-11-2017 04:29 PM
customsoftail200
02-07-2016 04:12 PM
biginchhustler
Shovelhead
12-18-2012 10:51 PM
DAYTONCHOPPERS
07-19-2011 08:32 AM
sutphen30
Ironhead
10-15-2008 02:50 PM
Quick Reply: Trans locks up in 1st and 2nd
