Primary/Transmission/Driveline/ClutchFind answers to general powertrain, primary and transmission. Have clutch issues and need suggestions? Post them here.
Trying to remove clutch basket but when I put tool between the gears to hold it so i can take off the nut, the gears stay put but clutch basket turns any way. The brake wont hold the wheel from turning. What am i doing wrong. I know its a reverse thread.
Thanks Quigley
I put a block of wood between the chain & the clutch & also between the chain & the front sprocket, bites in real good. You could also try an impact on the clutch, sometimes that helps.
