Primary/Transmission/Driveline/Clutch Find answers to general powertrain, primary and transmission. Have clutch issues and need suggestions? Post them here.
squeaking noise when downshifting
Old 05-14-2007, 12:58 AM
94 Heritage's Avatar
94 Heritage
94 Heritage is offline
6th Gear
Default squeaking noise when downshifting
I have a 94 heritage and I am getting a squeaking noise when I downshift. It happens at the beginning of the downshift when the rpm's are high. If I engage the clutch the noise stops. Also as the rpm's go down the squeak goes away. It almost sounds like a squeaky belt on a car. This is the only time I get any noise is on the downshift. Doesn't squeak when driving and going through the gears, only on the downshift. Any ideas? Thanks for your help.
Mike
Old 05-14-2007, 02:39 AM
TalkLikeAPirate's Avatar
TalkLikeAPirate
TalkLikeAPirate is offline
Default RE: squeaking noise when downshifting
I think it could in fact be the belt as you have already mentioned describing the sound. If it is the original belt from 94' there could easily be some glazed edges. just rough the edgesup a little bit with sand paper and see if it helps. Thats about the cheapest fix compaired to buying a new belt. Its possibly something else but try the easiest stuff first. right?
Old 05-15-2007, 09:24 AM
94 Heritage
6th Gear
I actually rubbed some regular old bar soap on the belt and I couldn't believe it but the squeak is gone. Thanks.
KelliCLE
05-19-2017 08:43 PM
draggingframe13
08-13-2013 11:42 PM
Falcon195
07-11-2012 07:26 PM
94 Heritage
08-08-2008 10:04 AM
ccrider
10-16-2006 01:02 PM
Quick Reply: squeaking noise when downshifting
