Transmission issue and traveling
Tried some searching but probably not using correct terms so will give a detailed description of what's happening.
Got oil and primary changed last week before big trip at my selling dealer using synthetics all around. Took off and went about 2400 miles without issue. Today had problem shifting to second. It would stop in neutral and I should have to reingage the clutch and put a little more pressure on heel of heel/toe shifter and it would shift. All upper gears would change with normal pressure. Downshifting was no problem.
On the way back issue became greater and could barely get into second. Removed heel and moved it 1 or 2 teeth higher. Perfect. So proud of myself. Well, you know the old saying, "pride before the fall". Got in interstate and shifted fine up to 6th gear. Needed to exit for gas and dilemma began.
Stuck on the road after exiting interstate and could not down shift at all. Shifter is totally "free wheeling". Had my corider come and by pulling the shifter outward, he could get it to catch and got it all the way to first. Had him move to third and feathered the clutch to get to motel. Looked underneath and no damage or leaking I could see or other damage. Thought the shifter shaft may have broken, but won't pull off. Just totally free. Linkage works.
Any ideas? Hopefully I can find a dealership that can get me in and back on the road as vacation is over and need to get back to work. It is a 2014 Ultra Limited with @16k miles.
Thanks
Thanks
Pop the top cover on the transmission and get the rear wheel in the air so you can spin it and shift manually through the gears. If you can get it to bind grab the shift forks and give them a wiggle. Each one should have a little play if any of them bind they could be bent and there is your problem child.
Yellow Glide (04-25-2016)
The following 2 users liked this post by sleazy rider:
Yankee Dog (03-24-2022),
Received 19,403 Likes
https://www.hdforums.com/forum/oil-a...ted-topics-30/
eighteight (03-24-2022)
cwsharp
08-22-2022 11:54 PM
