Primary/Transmission/Driveline/Clutch Find answers to general powertrain, primary and transmission. Have clutch issues and need suggestions? Post them here.
Inner primary bolt(s) part number?
Old 05-25-2016, 06:54 AM
hAkron's Avatar
hAkron
hAkron is offline
Default Inner primary bolt(s) part number?
im going to be removing the primary on my 2006 Dyna to replace the drive belt, and upgrade the IPB. There are 5(?) bolts with a rubber seal that hold the inner primary to the bottom end of the engine that you should replace if you remove the inner primary, but I'm having a hell of a time finding a part number so that I can order them. Anybody know what they are called, or have a part number?
Old 05-25-2016, 07:41 AM
IrishHogtrotter's Avatar
IrishHogtrotter
IrishHogtrotter is offline
Part No: 786A (5 of)
Old 05-25-2016, 01:57 PM
hAkron's Avatar
hAkron
hAkron is offline
Is it the whole bolt I need to replace, or just the rubber gasket on it?
Old 05-25-2016, 03:21 PM
IrishHogtrotter
Its the whole bolt, it comes with the sealing washer moulded to it. They are about $3 each, more or less.
Having said that, I have re-used the old ones without having any problems before, but it's up to you....
hAkron (05-25-2016)
Old 05-25-2016, 07:54 PM
LQQK_OUT's Avatar
LQQK_OUT
LQQK_OUT is offline
Received 1,563 Likes on 1,082 Posts
There are online parts manual links that you can use to lookup the part numbers one might need.
http://partsfinder.onlinemicrofiche....CASE%20HOUSING
https://www.hdforums.com/forum/gener...ual-links.html
hAkron (05-25-2016)
Old 05-25-2016, 08:12 PM
hAkron's Avatar
hAkron
hAkron is offline
Thanks a bunch. The bike is 10 years old, so I might as well replace them.
Old 05-25-2016, 08:13 PM
hAkron's Avatar
hAkron
hAkron is offline
Ive used the Ronnie's HD parts finder in the past, but I didn't see this bolt in their diagram this time.
Old 05-26-2016, 05:44 AM
LQQK_OUT's Avatar
LQQK_OUT
LQQK_OUT is offline
It is part number 1 in the above link if you haven't already noticed.
Old 05-26-2016, 07:47 AM
hAkron's Avatar
hAkron
hAkron is offline
I see that now, but looking at the diagram, it looked to me like that bolt is going into a hole where the outter primary bolts to the inner primary, that's why I was confused. Admittedly, I'm not super smart on my best day, so anything even slightly confusing will always mess me up.
bipolarsporty
09-06-2013 11:35 AM
JustDave71
11
04-12-2010 12:14 PM
boggesse
06-30-2009 05:10 AM
billymons
05-31-2009 10:52 PM
nosinjcted
35
03-09-2009 08:32 AM
Quick Reply: Inner primary bolt(s) part number?
