Primary/Transmission/Driveline/Clutch Find answers to general powertrain, primary and transmission. Have clutch issues and need suggestions? Post them here.
drive belt life
Old 09-01-2016, 07:19 PM
clackavosticus's Avatar
clackavosticus
clackavosticus is offline
Default drive belt life
I was wondering, how many K's should I expect to get out of my drive belt before it becomes unreliable and prone to breaking?
Only I want to change it out well before it comes close to breaking, leaving me stranded on the side of the road.
Old 09-01-2016, 07:34 PM
HDmikie's Avatar
HDmikie
HDmikie is offline
I have friends who have 100,000+ miles on their original belt. Also have a friend that had his belt break at 18,000 miles due to a rock that got between the belt and pulley.
That said, be sure to check it once a year for cracks or tears.
Old 09-02-2016, 12:23 AM
OldEnuf2NoBtr's Avatar
OldEnuf2NoBtr
OldEnuf2NoBtr is offline
Received 1,811 Likes on 1,064 Posts
+1 on 100,000+ miles or in your case 160,934+ kilometers.
Old 09-02-2016, 06:04 AM
grbrown's Avatar
grbrown
grbrown is offline
Received 2,851 Likes on 2,419 Posts
Just inspect at the stated intervals in your service manual. A few years ago I found a thin sliver of flint stuck in mine, having cut through to the outside. I removed it and carried on riding, but checking it more often. After about 4k miles the wound in the belt began to change it's appearance, I also had a long trip planned, so changed it. Even when damaged they can carry on for a while. The other thing to observe is correct tension. Check with the correct tool and don't run it either too tight or slack.
T Man
07-30-2019 05:56 PM
glidein wide
EVO
27
01-11-2015 08:23 AM
xwhyz1959
04-28-2012 01:52 PM
PanHeadRich
02-06-2011 12:10 AM
lecomte38
02-18-2008 09:47 AM
Quick Reply: drive belt life
