Primary/Transmission/Driveline/Clutch Find answers to general powertrain, primary and transmission. Have clutch issues and need suggestions? Post them here.
First Gear 'Bang"
Old 10-19-2016, 09:00 AM
VARSHIZZLE's Avatar
VARSHIZZLE
VARSHIZZLE is offline
6th Gear
37200131 clutch actuator,secondary $65.86
fyi
Old 10-19-2016, 11:03 AM
ROCKOUT Rocker Products
ROCKOUT Rocker Products is offline
Sponsor
Received 1,628 Likes on 1,176 Posts
fyi
Thanks, but the question remains can you sell me one?
For ROCKOUT information & purchasing please click the links below...
__________________
NO, they DON'T all do that!
Also on amazon.com...
Old 10-19-2016, 01:44 PM
Larry64's Avatar
Larry64
Larry64 is offline
Turn up the radio, I like that one. I figured it was clutch drag. Just kinda annoying. For what it's worth I'm using formula + in the primary and Spectro 6 speed in the gear box.
Old 10-20-2016, 01:07 PM
IRON1250's Avatar
IRON1250
IRON1250 is offline
Just had my 91 evo in the shop for a 5000 miles service. They replaced the transmission sprocket with the wider upgrade kit. Now I have much more clunk upon shifting from N to first. Not sure if it's the change in the fluid, new parts or poor clutch adjustment causing it.
Old 10-20-2016, 05:37 PM
Jackie Paper's Avatar
Jackie Paper
Jackie Paper is offline
Received 4,537 Likes on 3,789 Posts
Do the clutch starting under the derby cover with 3/4 back off from zero play. Be sure to screw in in two to three turns past no play to deburr thread and then the back off. Then, make sure your lever only has about 1/32 free play with the cable length adjuster. What is a 'transmission sprocket with the wider upgrade kit'??
Old 10-21-2016, 09:33 AM
IRON1250's Avatar
IRON1250
IRON1250 is offline
I think it's just the front drive belt sproket. I guess they were to thin from the factory and would strip the spline they mount on. Listed as transmission sproket 32 on the invoice.
Old 10-21-2016, 02:02 PM
Next In Line's Avatar
Next In Line
Next In Line is offline
When I was running the Hayden M6, I never had the clunk of shame.
rkc915
08-01-2015 03:38 PM
thomasf59
11-16-2014 10:20 AM
Rick7938
01-12-2013 08:21 PM
kelton3
02-24-2011 12:39 PM
Danbo47
07-12-2010 06:01 AM
Quick Reply: First Gear 'Bang"
