Primary/Transmission/Driveline/ClutchFind answers to general powertrain, primary and transmission. Have clutch issues and need suggestions? Post them here.
I've read through the posts on here about on the proper way to adjust the clutch. My issue is, no matter how far i turn the adjuster screw back (counter clock in the primary) my release is still way out from the handlebar. I started with backing off a 1/4 turn all the way to a little over one full turn and still with the same results!! Every time i adjusted i did it with it cold and adjusted the cable to have just a little play.
Any ideas??
I guessing you don't like where it releases but it is actually a good thing that means you are getting good travel and good plate separation.
that being said if you want to have it release closer to the bar back it off more.
