Difference between primary and transmission??
I'm ready to do my first oil change on my XL 1200 Cand was planning on doing the transmission oil as well. I'm a bit confused about the terminology I've seen on the forum so I'd thought I'd post here.
I have a copy of the service manual and I think the engine oil is easy enough. I get confusedwhen it comes tothe "transmission" and "primary". If I'm correct about this, I remove the plug below the derby cover to drain the transmission fluid. I then loosen the derby cover (after replacing the drain plug of course) and pour the oil in the crankcase. When the desired level is reached, replace the cover. If I'm correct about the above statement, the tranny oil change is complete. Questions - Is anything attached to the underside of the derby cover?? How easy are the covers to replace yourself? (I might change mine with the oil.)
What then is the primary and how does it differ (if at all)from the tranny??The reason I ask is because in other areas of the forum I've seen 3 different types of lubrication listed - one each for the engine, primary and tranny? The shop manual it says the engine oil, oil filter and primary chaincase/transmission lubricant should all be replaced @ 5k miles.There is no mention made of a "primary" oil change procedure...Any help will be greatly appreciated.
Jason Bourne (03-11-2024)
RE: Difference between primary and transmission??
hey dave............NO THEY DON"T. the only thing that harley ever built that shares engine oil is some of the shovels that oil the primary with a drip from the oil pump and then returns it to the engine. sportys have trans/primary fluid, and oil.... through all the years.
Changed both the engine oil and the primary/transmission oil tonight after all...Had the most trouble taking off the derby cover (didn't have a size 27 torx, only 25 and 30) and found that I really didn't need to take it off at all. I have more room to refill the crankcase if I remove the primary inspection cover and use a funnel. I used the Formula + for the tranny and Racing Lucas Oil Full Synthetic 20W-50 for the engine. Next change I'll use the Syn3 HD Oil (already bought 3 qts yesterday), though I don't know what I'll try in the tranny. Didn't notice abigdifference with the Formula + yet (i.e. reduced noise, etc.) May try something suggested in the posts here. Thanks for all your help...
razzell2 (02-10-2022)
ORIGINAL: jmetro
BklynBound
Oil Archive (no new posts)
08-26-2022 06:27 PM
