Which non-Harley oil for transmission and primary?
ATF should be Ok, because car transmissions have clutches like bike ones and they have chains. ATF will eliminate dragging clutch in cold mornings.
Anyone who has taken the time to read all or at least a substantial number of the oil forums - or maybe an oil tech here - able to explain the Primary Oil choice? I am under the impression the Primary is just a "Wet Clutch" application - any lubricating fluid is effective. More to the point, I have 24K on my bike, last 12K I have had Royal Purple in the Primary and it feels as if the clutch will not fully hook up. I cannot explain it - and I acknowledge this could be entirely in my head - but at highway speeds, I just have this feeling the clutch is slipping. Good connection on the low end, it is just the top end that gives me this impression.
Is it possible that RP is literally too slippery for this application?
I went RP when a guy at my local shop was explaining to the service writer that he (owner) knew what was leaking because he had purple in the primary, red in the trans, and brown in the crank. It made so much sense I figured I would do the same.
Anyone else running RP in your primary? What are your opinions?
1. You can add sand to your primary to make oil not slippery
2.Replace weak spring. Check disks thickness just to feel smart, it is going to be weak spring anyway.
First one is cheaper.
Dump the RP and run any good 10W40 in the primary; might have to run for 500 miles and change again but any name brand 10W40 conventional will work fine in the primary. Some will insist the primary should be 20W50 which is fine but I haven't had any issues with 10W40. Redline Shockproof has always worked well for me in the trans and the fact that it is red does make differentiating between an inner primary or transmission leak easy is an added benefit.
Note; You can use Mobil 1, 15W50 car oil in a H-D V-Twin motor, BUT, NOT in the Primary!
Received 2,858 Likes
Maybe you can enlighten the forum on which of the name brand oils still include friction modifiers and identify the friction modifiers? I believe you will find very few, if any.
Forum members, please do not be afraid to run name brand 10W30 or 10W40 in your primary; no harm will come from it.
