15' RG Primo Pro
15' RG Primo Pro
I am going to be installing Primo Pro in my 15 RG. I am trying to figure out what is the best unit to go with. I am not going crazy on the build, it is a 107" that is roughly 115hp and 128-130tq. I had a AIM VCP installed but it doesn't hold until the rpm's come up. The Dyno is showing a slip in the clutch from about 2800-3900. I am not sure which Primo Pro I should be going with. Any info and help would be appreciated.
Thanks
Pete
Thanks
Pete
Thanks
Pete
Thanks
Pete
Mighty salty number for a 107" motor; don't know anything about the Primo Pro. Perhaps you don't have the right VCP? The VCP in my all bore 107" motor at 124TQ/110HP holds off idle; no issues. However, if looking for another clutch, lots of good reports on the Bandit Sportsman.
Now I am not sure how accurate that will be but I did ask him if he will rerun it on the Dyno after I install the clutch and he agreed.
I am happy with the numbers that I have currently but IF they hit what he thinks they will with the clutch with the Woods cam that I have and a 10.35:1 CR I will be crazy HAPPY
Pete
brad75raiders
04-25-2018 01:00 PM
low loud phatboy
09-03-2008 07:30 PM
