Primary/Transmission/Driveline/Clutch Find answers to general powertrain, primary and transmission. Have clutch issues and need suggestions? Post them here.
98 FLHTCI Oil pan change
Old 12-09-2007, 01:42 PM
rkmv's Avatar
rkmv
rkmv is offline
1st Gear
Default 98 FLHTCI Oil pan change
The drain plug on the Tranny/oil pan has stripped.... does the transmission have to be completely removed to replace the pan???
Old 12-10-2007, 01:11 PM
js124's Avatar
js124
js124 is offline
Default RE: 98 FLHTCI Oil pan change
I should be doable with out removing the trans . This is out of memory . I'll look tonight .
Old 12-10-2007, 01:12 PM
js124's Avatar
js124
js124 is offline
When you do I would like you old pan to use as a templet .
aces&8s
Exhaust System Topics
11
09-09-2013 04:42 PM
bubdifab
07-17-2013 06:52 PM
keeferfish
Oil Archive (no new posts)
15
08-04-2011 08:50 AM
pappy
02-07-2009 09:58 AM
huntinjoe
05-21-2007 12:19 PM
Quick Reply: 98 FLHTCI Oil pan change
