clutch spring pressure adjustments
Im putting anew clutch hub,pressure plate (aluminum type),and new stock springs. How do I adjust the spring pressure? The HD manual talks about a 1 1/32 measurement from the spring collar to the back of the pressure plate. With the pressure plate being a different style should I measufe from the (face) of the plate to the spring collar,then add the thickness of the stock one to it or is there another method? I did add aextra disc and steel plate. please reply
RE: clutch spring pressure adjustments
I am running one of the aluminum pressure plates on my shovel andthe wayI do it is to measure the depth of the holes the springs set into - to the outer surface of the pressure plate ( the surface AWAY from the clutches ) Then subtract this number from the total distance harley gives you, you say 1" 1/32( or whatever) so lets say the springs are 1/2 in (or 16/32) down into the pressure plate then your measument would be33/32 - 16/32= 17/32 Thats if your using the stock spring collar
it doesn't matter if you added any clutch plates since the whole pressure plate / spring packmoves out as a unit. its just further out on the studs.
although with extra plates you can get away with a little less pressure for the same result in my opinionbut that is a whole nuther topic for discussion.
Hope this helps
Hope this helps
Roc Rat
03-18-2015 01:57 PM
Bankrupt
03-03-2012 03:34 PM
