ATF fluid in primary???
RE: ATF fluid in primary???
Compensators on older bikes simply had grease smeared on them upon assembly. Granted they would eventually wear out.
As mentioned earlier, ATF is also used in heavy duty transfer cases with chain drive for the front wheels drive componentsand lots of heavily loaded bearings.
And anyone using motor oil OF ANY KIND in their primary is asking for trouble. Fine for the chain and bearings, but NO GOOD for the clutches.
just did a fresh rebuild on a 1980 FLT i get it all back together & have clutch drag at low rpm's been in & out of the primary 5-10 times adjusting. even went in all the way for oil seals & new gaskets & bearings. still have the freakin drag. my local wrench told me to use RevTech's primary oil to fix low rpm clutch drag Q:now do i skip that mess & go right to ATF????
ORIGINAL: t150vej
My '02 Ultra has 10w30 in the primary and has been fine for 47k miles. If anyone thinks that is wrong or something else should be use, Im open for suggestions.
Motor oil in the primary is fine.......as long as does not say "Energy Conserving" on the bottle. Most 10w30 and below should be avoided. 10w40 and up work just fine. Synthetic or regular does not make any difference.
Harley's own old type primary fluid, SYN3, regular 20w50, including the Formular Plus are fine to use in the primary.
I totally agree with Dalton when it comes to warranty. If your bike is under warranty....useATF at your own risk.
I would like to mention though....probably something like 20-30 years ago. I heard several riders using ATF type F and were having trouble. The ATF was causing the magnets inside the rotor to come loose....consequently killing the rotor and sometimes the stator as well.
I am not "recommending" anyone change to ATF. I am running it and th clutch manufacturer recommends it. The clutch is so smooth and have very positive desengagement and very smooth shifts. As far as the rotor/stator issue, I have not heard that one and wonder how valid it was as again, a lot of the aftermarket hi-perf clutch manufacturers recommend ATF, although Dexron II or greater, not the old type "f"
