ATF fluid in primary???
RE: ATF fluid in primary???
ORIGINAL: lonewatie
other than the cost for the quart, why not just use what's recommended and not re-invent the wheel?
And yes, the ATF is $1.98 a qt, but do you really think I care what it costs with what I have already invested in by bike???
thanks - was just curious.
ORIGINAL: Dalton
Using that rational,I wouldn't have built the engine either.And everybody would run HD engine oils. The Dexron II ATF is recommended by the clutch manufacturer - Rivera-Primo who has been buildinghigh performance clutches as long as I have been riding. There is always something new, better, different, and sometimes it actually works better.
ORIGINAL: lonewatie
WHY
Just run HD F+ or plain old motor oil not SNY.
Sny have molly additives in it not good for the clutch.
In the primary you could almost get away with peanut oil it not that big a deal.
If you want to worry about siome thing Tranmission and engine now theres were you can get some bang for your buck running good lubes.
glad I fouind this post.Ive been having problem with clutches since switching to hydraulic clutch.Never thought about the oil in side primary.I ran atf in springer before the open primary.I think ill give it a try.Hey anyone need quart of fresh primary oil I just dumped in day ago.oh hell olny 5 bucks and new clutches are lot more .My problem has been when speed shifting on hard runs,it starts running thru the clutch in fourth and fifth after cpl hard shots.
I just changed mine and added Rotella T syn. I've used it in my metric, wet clutch, engines for years and the added detergents should keep the moving parts clean.
When the guy bought my 1100 with 80,000 the compression test was perfect and still had the original clutch.
I use Redline MTL in my primary. MTL is a 70w80 synthetic manual transmission lubricant that has no moly and has a pour point like a 5w30 motor oil so you get little or no clutch drag when its cold. It's just a tad bit thicker than ATF so it provides excellent lubrication to the bearings & other drive components. Redline has been specifying this lube for HD primary applications for almost 20 years with good results. I really like it as I get excellent clutch feel.
