32 tooth Compensator Sprocket
Does anyone make a 32 tooth compensator sprocket for a 2007-2008 FLHT? I know that Evo makes a 30 tooth sprocket that eliminates the compensator and the reason they don't have a kit for 32 teeth is because the primary chain required to work with the 46 tooth clutch sprocket makes the stock chain to long to work with the auto chain adjuster or the the shorter chain to short period.
Evo also makes a 49 tooth sprocket kit for the clutch #EV-38556.
If you take this kit and add a 32 tooth sprocket you end up with a primary gear ratio of 1.53 to 1 and a final drive ratio of 3.16 to 1. I would think the stock chain lenth would be close to making this work, one tooth or should I say on chain pitch lengh shorter? Wouldn't this work? I have a email into Evo to see what their response is.
But to me you would have the best solution here, lower ratio and mantaining the compensator in place.
Can anyone provide the center distances between the motor shaft and the clutch shaft? Also what is the primary chain type, size and pitch, I do know it's made by diamond?
Nine-n-a-half
04-12-2017 09:46 PM
