EVO Sportster oil line routing
Hi,
I am trying to figure out how to run the oil lines for my sporty motor in my rigid. \\; As I understand it, the bottom oil line fitting on the oil pump is the supply, but I have 3 vents, which one is the return line? \\; The front drive sprocket cover...when you take that off there is a fitting in the upper right corner, and there is another fitting right in front of the rear motor mounts. \\; The third vent comes off the cylinder heads. \\; I'm jsut trying to figure out which is the return line, as the engine vent will go to the top of the oil tank, and the cylinder head vent and tranny/primary vent will both do to the ground with a small K&\\;N filter on the ends.
Anyone please tell me what's the deal here?[&:]
Thanks,
~Joe
Thanks,
~Joe
policeking
Oil Archive (no new posts)
12-22-2012 07:37 PM
