Primary/Transmission/Driveline/ClutchFind answers to general powertrain, primary and transmission. Have clutch issues and need suggestions? Post them here.
I have a 08 FLSTC and drained the oil from the primary. \\; I went to remove the primary cover and the first bolt came loose fairly easy. \\; I broke the torx bit when trying to remove the second one. \\; Had it replaced thanks to SEARS but now I can not get the other 4 bolts out. \\; The heads are starting to strip. \\; These things are on way to tight. \\; Any ideas how to get this off so I can get oil back into the primary and ride this weekend?
If they strip carefully drill the heads off , remove cover, remove studs with pliers. Replace with #20 coarse thread 3/4" long allen head SS screws from true value for $2
