Primary/Transmission/Driveline/Clutch Find answers to general powertrain, primary and transmission. Have clutch issues and need suggestions? Post them here.
1 3/16" Nut on Clutch
Old 12-04-2008, 03:55 AM
michiganmarty's Avatar
michiganmarty
michiganmarty is offline
Default 1 3/16" Nut on Clutch
To remove the clutch pack as an assembly you have to use a 1 3/16" socket to remove the LH threaded, shoulder type nut. The manual does not mention how it goes back on: with the nut against the clutch hub - or the shoulder against the clutch hub. I took it apart, and I should know how it came off, but I cannot remember! Oops!
Can anyone help me out here?
Old 12-04-2008, 08:57 AM
miacycles's Avatar
miacycles
miacycles is offline
Nut out, shoulder in.
Old 12-04-2008, 09:46 AM
TXCHOP's Avatar
TXCHOP
TXCHOP is offline
Yup, and dont forget lockite!
Old 12-05-2008, 01:18 AM
michiganmarty
Great help, Thanks guys - I do appreciate it.
Old 12-05-2008, 02:57 PM
stroker1948's Avatar
stroker1948
stroker1948 is offline
Shoulder in, red locktite and torque to 80 foot lbs.
larooj42
EVO
05-28-2015 08:43 AM
larooj42
05-19-2015 03:33 AM
old evo
01-06-2013 11:13 AM
sdguyman
01-15-2010 09:44 PM
skeyediver
10-13-2008 10:29 PM
Quick Reply: 1 3/16" Nut on Clutch
