Primary/Transmission/Driveline/Clutch Find answers to general powertrain, primary and transmission. Have clutch issues and need suggestions? Post them here.
'82 FXR, is my clutch wet or dry
Old 01-25-2009, 07:40 PM
wrinspect21's Avatar
wrinspect21
wrinspect21 is offline
Default '82 FXR, is my clutch wet or dry
Just picked up a 82 FXR, is it a wet or dry primary system? If wet, how much oil goes in and what weight?
Old 01-25-2009, 07:51 PM
notlost_nc's Avatar
notlost_nc
notlost_nc is offline
dry, Look at the backside of the inner primary, if you have two hoses connected you are still recirculating the engine oil and don't need to add any oil to the primary itself. I've isolated my primary and I use about 7 ounces of Spectro Primary Chaincase oil in my '84 still using the dry clutch.
Old 01-26-2009, 07:56 AM
KBFXDLI's Avatar
KBFXDLI
KBFXDLI is offline
Big Kahuna HDF Member
Wouldn't it be a wet clutch if there is oil in it?
Old 01-26-2009, 09:40 AM
texas tom's Avatar
texas tom
texas tom is offline
Don`t know if it matters wet or dry but you dont add oil to it (the primary) in stock configuration the oil from engine drips onto the primary chain then is scavenged at the bottom and recirculated into the engine,this is one reason them old shovels leaked oil all the time. Tom..
Old 01-26-2009, 01:56 PM
notlost_nc's Avatar
notlost_nc
Once you isolate the primary from the main oil supply there is no longer a source to drip on the chain. 6 or 7 ounces at the bottom of the primary is enough to keep the chain lubed. The plates are still dry.
Old 01-26-2009, 02:06 PM
KBFXDLI's Avatar
KBFXDLI
KBFXDLI is offline
Ok, got it. I was thinking a shared sump with the engine. DOH!!!
A#1
Oil Archive (no new posts)
11
06-07-2019 05:43 AM
cjshovel
Shovelhead
04-08-2011 09:19 AM
outlawrider
06-24-2009 10:04 PM
skos
04-20-2008 02:19 PM
Gra490
EVO
31
04-15-2008 02:13 PM
Quick Reply: '82 FXR, is my clutch wet or dry
