Primary/Transmission/Driveline/Clutch Find answers to general powertrain, primary and transmission. Have clutch issues and need suggestions? Post them here.
Rebuilding a 4 spd transmission (+++PICS)
Old 03-03-2009, 09:06 PM
skycrane's Avatar
skycrane
skycrane is offline
Default Rebuilding a 4 spd transmission (+++PICS)
Hey how's going? This 4 speed transmission has been rebuilt twice in the last 5 years to the tune of $2000 dollars. Well it leaked like a stuck pig within a month of being rebuilt last time. I have now taken the bike over from a family member to help solve this leak problem. I can say it leaks from the clutch rod shaft opening and from the main shaft itself. Does anyone know where I can get some info on changing all the seals? I've ordered up a JIM's master gasket/seal kit. Here's some pics so far..I will provide pics as I go along. If anyone has any tips let me know.
cheer
Old 03-04-2009, 09:03 AM
sqdealgeorge's Avatar
sqdealgeorge
sqdealgeorge is offline
What year FXWG is this 84/early 85? Very clean looking
Old 03-04-2009, 09:34 AM
skycrane's Avatar
skycrane
skycrane is offline
The bike has been completely chopped:
-Frame 1974 FLH
-Frontend 1970's FX
-Eng S&S Evolution
-Dry belt drive primary
-fat bob fender kit
-hyd clutch...
-V&H straight Shot HS
-Super G carb
Old 03-04-2009, 06:17 PM
sqdealgeorge
Why would someone put a rotary trany on a bike that should have had a ratchet lid !!! These trany's were inferior HD's solution to installing a rear belt drive Are you going to install a rear belt in the future ? As you can see I never liked these trany's Maybe install a 5 speed in a 4 I run one in one of my customs (96 CI S&S ) I love it
Old 03-04-2009, 07:37 PM
skycrane's Avatar
skycrane
skycrane is offline
For now I'm just looking to get it from leaking. It's blowing up primary belts from soaking them in oil. Got stranded big time last year on a ride... The tranny itself shifts fine for what it is. No plans on a rear belt just bought a new chain for it. What can i say, it's old and I can't afford a new bike right now..
Old 03-05-2009, 07:37 AM
sqdealgeorge
Out of curiosity does your primary belt use an idler for tension ? I'll check my inventory for the main shaft seal ( inserted into 4th gear ) and the trany nut seal The rest are o'rings I'll check part #'s
Old 03-05-2009, 09:34 AM
skycrane's Avatar
skycrane
skycrane is offline
The primary belt does not have a tensioner its tensioned on size only. I've ordered the JIM's seal kit but im strongly thinking of changing the main shaft.
Old 03-05-2009, 12:50 PM
sqdealgeorge
Changing the main shaft is a good idea They do wear at that seal point
Old 03-06-2009, 09:52 AM
skycrane's Avatar
skycrane
skycrane is offline
Here's a great turorial on how to change the seals on a ratchet top older model 4 speed I thought was worth sharing...update on my build..the main shaft is on it's way out today pictures to follow..
http://www.streetchopperweb.com/tech.../photo_01.html
I found the culprit. The main bearing seal spacer had a lip worn in it and a fubared O-ring. Exactly what somebody on this side told me would be the problem. Here's some pics of the progress so far. The key to removing the main shaft is to find the circlip and slid it up over the splines..i missed it the first time looking around.
Daddy454
06-18-2019 04:34 PM
1890jd
EVO
05-01-2019 08:33 AM
maverick31210
Shovelhead
04-30-2018 11:48 PM
Spanners39
EVO
12-10-2012 04:41 PM
Mathews2
08-26-2009 06:58 AM
Quick Reply: Rebuilding a 4 spd transmission (+++PICS)
