Primary/Transmission/Driveline/Clutch Find answers to general powertrain, primary and transmission. Have clutch issues and need suggestions? Post them here.
fxr clutch hub removal question
Old 03-22-2009, 07:12 PM
lowglide88's Avatar
lowglide88
lowglide88 is offline
Question fxr clutch hub removal question
Hey guys...I am in the process of removing the clutch hub on my 1988 FXRS...I've watched it been done before,but this is the first time I'm doing it...once I've got it apart to the point where I put the puller on the hub.. with it in gear and applying the rear brake...I just tighten it down until the hub pops off right?...if there is any tips anyone can give to help with the job it would help....thanx
Old 03-23-2009, 11:07 AM
sqdealgeorge's Avatar
sqdealgeorge
sqdealgeorge is offline
You don't have to put it gear or apply brake as you tighten the hub removal tool it should pop maybe alittle heat on the clutch hub only and a light tap with a hammer on the removal tool When you get it off look for cracks around the taper
anything2wheels
24
04-23-2018 10:49 PM
stephanbpedersen
Shovelhead
07-24-2017 05:53 AM
gsxrboy96
EVO
05-11-2012 11:04 AM
Bama91
06-10-2011 01:28 AM
Harley_Dude
EVO
05-24-2008 08:15 AM
Quick Reply: fxr clutch hub removal question
