Tranny Noise Coasting in First
I am seeking confirmation of what I was just told by my HD service advisor. Symptoms are: while coasting in first, with clutch level pulled in, a whinning, squeeking, buzzing type noise comes from the tranny.
As soon as I shift to second, the noise goes away. This did not start all at once, it came on gradually over a span of a few days. It became really noticeable yesterday at the end of a ride going between several shop signs with no road noise, etc.
I was told by the service advisor the noise is typical of the six-speed tranny; that first and fifth gears are straight cut, whereas all other gears are helical cut. He said the sound I am hearing is normal and not to worry about it.
This is my first Harley so am not accustomed to their quirks.
Comments??
Jim
Comments??
Jim
Comments??
Jim
Comments??
Jim
Interesting, mine does make a whine and understand, perhaps misunderstand, that this is due to the 1st and 5th gears being straight cut in the 6 speed transmissions while all the other gears are helical. The straight cut gears add noise but a synthetic oil should help lessen the noise.
Yes they do whine but in this case with the clutch in there is no load on them to make the typical gear whine. The sound I'm referring to is only with clutch pulled in and in first gear coasting with quicker than normal speed for that gear. The whine actually stops if you let the clutch out and put the load back on the trans. Hard to describe but it's more like a quiet turbine whine than straight gear back out of your driveway with a standard sound.
Ron
Ron
Similar problem, never could find an answer: Rolling to a stop, pull in clutch at low speed, get a whirrrr until bike is stopped. Happens randomly, not every day, more often when cold, but also when warm. Kick into neutral after stop, no sound. Clutch, primary chain, and belt checked and in adjustment. Primary and trans changed to synthetic, no difference. Does not effect anything else...clutch and trans work perfectly. 2000 Softail, 5 speed.
Ron
