Primary/Transmission/Driveline/Clutch Find answers to general powertrain, primary and transmission. Have clutch issues and need suggestions? Post them here.
94 wide glide shifter fork check
Old 05-17-2009, 01:18 AM
dogsong_1013's Avatar
dogsong_1013
dogsong_1013 is offline
Default 94 wide glide shifter fork check
i think I have a bent shifter fork and from what i can tell it looks like I could remove the exaust and the top cover to the tranny and acess the shifter drum and forks from there wirhout removing the wole S*** and shebang. does anyone know if this is possible and does anyone know af where i could download exploded art r better yet even in structions for doing this? the scoot is a 94fxdwg. Also can a bent shifter fork be straightened or does it HAVE to be replaced? The bike operates fine other than not going in to fourth ( just act like its in neutral).
Thanksfor any insight,
Will
Old 05-17-2009, 03:21 PM
Dan89FLSTC's Avatar
Dan89FLSTC
Dan89FLSTC is offline
Received 8,497 Likes on 4,612 Posts
With rear wheel off the ground and battery disconnected:
Remove the top transmission cover by removing the bolts that hold it on…
Once the top cover is removed, inspect the springs on the shifter pawl.
Checking the shifter pawl adjustment:
With the transmission in 3rd gear, check the distance from the pins on the shifter drum to the arm on the shifter pawl, the distance should be equal on both sides (the shifter pawl is the arm that rotates the shift drum by grabbing the pins, watch how it works as you shift the gears and you will see).
To adjust the shifter pawl, loosen the locknut nut on the outside of the transmission case (left side, near the shifter shaft), rotate the screw until the pawl is centered over the shift drum pins, tighten locknut.
Now try shifting the tranny into 4th gear, you will probably need to rotate the rear wheel back and forth so the dogs line up on the gears.
If it is still not shifting into 4th gear, remove the shift drum, be careful with the bolts and washers, they could be a pain to get out of the transmission...
4th gear fork is the one on the right side, to remove forks, you must remove the clutch mechanism cover on the right side of tranny, it is the chrome cover that the clutch cable goes into.
Once the cover is off, slide the shift fork shaft out and remove the forks.
There is no repair for a damaged shift fork, they go into the scrap pile.
PleaseHelp
EVO
01-09-2019 09:02 AM
Ramblingwreck
05-29-2016 10:09 PM
alkrisma
07-04-2011 03:20 PM
dogsong_1013
04-09-2009 07:06 PM
TedH
04-10-2006 08:28 AM
Quick Reply: 94 wide glide shifter fork check
