Harley Davidson Forums
Harley Davidson Forums - Harley Davidson Classifieds - HDForums.com Photo Galleries - Create an Account - Harley Davidson News
Go Back   Harley Davidson Forums > General Harley Davidson Tech Forums > Primary/Transmission/Driveline/Clutch
New! Use your Facebook, Google, AIM & Yahoo accounts to securely log into this site, click logo to login
Primary/Transmission/Driveline/Clutch Find answers to general Drivetrain and transmission questions here.
Welcome to HDForums.com!
Welcome to HDForums.com.
Thread Tools Search this Thread
Old 11-16-2009, 08:25 PM
dirty1east dirty1east is offline
Hang Around
Default Getting into first on my 5 speed
Whether I'm at a stop or rolling to one at low speeds, my 88" does not like to go into first gear. I did a cable adjustment and made sure I had approx 1/8" or so in play, lubed the cable, and cleaned out the clutch perch and lever to no avail. I have no problems going through the gears up or down; it's always first gear. The fluid level in the tranny is spot on too. Thoughts?
This ad is not displayed to registered and logged-in members.
Register your free account today and become a member on HD Forums!
__________________
07 FLHR 04 FXD
Rush SO 1.75(L) 2.25(R) KW HP SO
ThunderMax w/ Autotune Mikuni HSR 42 kit
ThunderMax Air kit
Mobile1 20-50 Primary
Royal Purple 75-140 Trans
Old 11-16-2009, 08:43 PM
dawg's Avatar
dawg dawg is offline
Did you adjust the clutch at the basket too? What are you running for fluid in the tranny and primary?
__________________
'08 105th anniversary Ultra
D&D Fatcat
Zippers Redshift 575 cams
EVO Ind. 30 tooth
SERT
www.vtroaddawgs.com
www.roaddawgs.com
Old 11-18-2009, 04:40 PM
Hang Around
Tanny I'm using MoCo factory stuff and MoCo 20/50 dino in the primary.
I didn't adjust the clutch at the basket. I thought that was only necessary on new bikes/cables cause of cable stretch?
__________________
07 FLHR 04 FXD
ThunderMax Air kit
Last edited by dirty1east; 11-18-2009 at 04:42 PM. Reason: forgot to respond to one of the responders questions.
Old 11-19-2009, 07:20 PM
Hang Around
I just went and did the primary adjustment along with the cable. I can get it into Neutral and all other gears easily but it does not want to go into first. I used the MoCo method and a method recommended on here in the "clutch adjustment" "search" to no avail. The clutch cable is at its max. It's an original FXD cable on mini apes that came with the Street Bob. Does HD use a different length clutch cable for the Bob's than the standard?
__________________
07 FLHR 04 FXD
ThunderMax Air kit
Old 11-19-2009, 11:08 PM
clicker01's Avatar
clicker01 clicker01 is offline
Probably not your clutch, since all other gears are okay, but you should check your shift rod adjustment.
Old 11-20-2009, 09:30 AM
Old Gunny Old Gunny is offline
20-50 oil is about 90 weight when related to gear oil. Can be too thick for easy shifting.
Primary needs a light oil suitable for clutch paks. Some lubrication of chaines and sprokets and a lot of cooling.
I just cut straight to it and use Amsoil ATF.
Same as I put into my, 1 ton 4 wheel drive, Dodge pickup.
More than likely other, "Primary" oils are really ATF kind of oils.
Old 11-21-2009, 08:56 AM
Hang Around
I'll dump the 20-50 and get some tranny stuff then.
I hadn't thought of adjusting the shift rod either. I'll give those a shot.
__________________
07 FLHR 04 FXD
ThunderMax Air kit
Old 11-21-2009, 06:21 PM
Hang Around
I am going to attempt to redeem myself here; I figured out where the problem was. It was a mere one spline on the shift lever. I don't know who assembled the bike or who the last person to mess with the shifter was but it was positioned so that when dropping into first, the lever came into contact with the foot peg bolt on the mid controls. It was enough to interfere with the range of motion of the shifter and once corrected, pretty much eliminated the problem. It's still a "Harley" clutch but at least I'm not feverishly trying to get into first a stop lights.
Thanks for the reply's, they are always appreciated.
__________________
07 FLHR 04 FXD
ThunderMax Air kit
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
Advertising
Featured Sponsors
Vendor Directory
New Sponsors
Advertising Information - Harley Davidson Forums - Archive - Top
© Internet Brands, Inc.
Powered by vBulletin® Version 3.7.1
Copyright ©2000 - 2010, Jelsoft Enterprises Ltd.
Search Engine Optimization by vBSEO 3.2.0
