clutch cable is leaking
I recently put braided cables on my bike with 16'' apes. I noticed the other day my new clutch cable has a small nick in the housing near the underside of the bike, exposing a small section of braided wire.. It produces a small leak, and i hate to buy a new set of cables already. Is there anything i could do to keep the cable from leaking...like maybe some silicone caulk?
Ron
There is an o-ring where the cable attaches to the transmission side cover. This should keep the transmission fluid from coming back through the cable. The only thing that I imagine would be "leaking" out of a nick in the line would be whatever you used to lube the cable, which shouldn't be enough to be constant. If you have a constant leak then you might want to check the o-ring. In any event, to fix your problem I would get some clear heat shrink tubing and disconnect the cable and slide it over the cable and then shrink it down. Most of the stainless braided cables do or should come with clear protective heat shrink tubing where the cable goes under the frame to protect it.
Ron
I'd check the vent at the tranny top cover first to make sure it's not blocked, then if that's not it, check the o-ring. Check the tranny fluid level to be sure it's where it is supposed to be and not overfilled. You may end up having to replace the cable anyhow.
Clutch cable leak
I just recently acquired a 2005 xl883 sportster and have come across this issue. I've read the other post on this issue but would still like to hear your thoughts. I'm getting fluid coming out of the barrel adjuster halfway up the frame! The primary fluid level is fine and cable/cable housing still look brand new.. Any thoughts?
I attached a photo of were it's leaking don't know if it will show.
Slings all over the bike while riding and when I'm done and put the kickstand down and get off it drips pretty good for a min. Or two
Thank you mdm , I the transmission vent was actually plugged. With some more searching I was able to find it then called the kid I bought it from and he said "he plugged it because he did not know what it was." Before I called him I unplugged it and it solved the issue . I just called to see if he had any particular reason why he plugged it.
