Primary/Transmission/Driveline/Clutch Find answers to general powertrain, primary and transmission. Have clutch issues and need suggestions? Post them here.
83 FXRS Clutch Issues?
Old 01-29-2010, 09:18 AM
Feaster69's Avatar
Feaster69
Feaster69 is offline
1st Gear
Default 83 FXRS Clutch Issues?
I have a 1983 FXRS with a 5 speed. When the restoration was first compleated the clutch was working fine. Then it started this weird problem. At take off it grabbs hard way before the clutch is all the way out. This is a progressive problem as it gets worse the more I ride it.
Any advice on this problem?
Old 01-29-2010, 07:34 PM
09DynaMan's Avatar
09DynaMan
09DynaMan is offline
bearing has collapsed on end of pushrod on trans cover end
Old 01-31-2010, 06:45 PM
Feaster69's Avatar
Feaster69
1st Gear
If that bearing is the throwout bearing it's on it's fourth one. Is there something that would cause that bearing to go bad? I'm kinda new to the world of Shovel Heads. Thanks for the advice.
Old 02-01-2010, 04:02 AM
09DynaMan's Avatar
09DynaMan
excessive spring pressure, and/or incorrect clutch adjustment
if there is no freeplay, the bearing is under load all the time
Old 02-02-2010, 10:35 AM
Feaster69's Avatar
Feaster69
1st Gear
Thank you for your help with this I will check it out.
blackbear
EVO
06-28-2013 11:07 PM
blair
06-25-2012 05:24 PM
guitarman023
06-04-2012 01:43 PM
DJ Baar
10-05-2011 10:49 AM
bulldawg10
11-06-2010 03:53 AM
Quick Reply: 83 FXRS Clutch Issues?
