Inner primary off
Inner primary off
Ok I have my inner primary off and also have the main trans drive gear off and going to replace all seals !!!
My question is I see a lot of post about replace mainshaft fifth gear seal 12035B !!!!
Where is this seal ???
I have the big seal behind drive gear out, shift shaft, seal out !!
There is a sort of plug to the left of the main trans shaft but that does not look like a seal!!!
You say you have the main trans gear off, but I think you mean the front belt pulley...
The main drive gear is the splined shaft that comes out of the trans that the pulley mounts onto.
The mainshaft is the long shaft that passes through the main drive gear. As Doc said, the seal is in the end of the main drive gear and seals the space between these two shafts.
Many people overlook this seal.
In addition to replacing the big seal and the mainshaft seal, I suggest you replace the pulley spacer and the quad seal that is underneath it.
Thanks guys,
I was gone all day Saturday my buddy sold his glodwing so we had to deliver it to St Louis Mo.
Today Im sicl on the damn couch!!!!
But I did go out and take a look, so that inner race has to come off???
Ps Im a Ford Technican but thios is only my 3rd Harley and the first time Ive ever had the primary off. Last winter was big bore kit cams head work.
Love working on stuff like this!!!
Yes, the inner race must come off.
You then need to clean that shaft really well with super fine emery, as in 2000 grit.
Remove seal with mechanics pick.
Clean bore, blah blah
Tape splines so new seal is not damaged when sliding on.
Lube seal lip.
Use tool to ensure seal is 0.090 below end of gear.
My tip...... Only install that seal when the pulley is installed, and fully torqued.
Lube seal lip.
LQQK_OUT
02-10-2019 02:36 PM
M&P340
07-10-2017 04:07 PM
Ls1cameric
10-01-2013 04:15 PM
