Primary Chain Stretch
Experience
My experience is it really does not stretch but it will wear unevenly due to the slight wear in the pin bores. Mine was abused due to misalignment.(see my album) . I did my best to measure it since Harley only say if you run out of manual adjustment replace chain and sprockets. I stretched it over large and small sprocket and measured across at different locations. Also gave it the old twist method (seemed OK). Stretched and measured between the same number of rollers at different locations. (all fairly close as best I could measure with dial caliper and outside micrometers) However when I put all back together I still have enough run out between loose and tight that it uses up the whole tolerance of my manual adjustment between loose and tight. I still have a lot of adjustment to go. Here lately since I still have a lot of noise is maybe I have a inner primary bearing going out that is some of the run out. I could not detect any sprocket shake when I had it all apart. Not totally clear how auto adjuster works but I do not believe you chain is stretch problem. My problem took 30K of abuse to produce. Do not think I could even use auto adjuster now. Have 40K on bike now. How many miles do you have and when did you put auto adjuster on? Did you bike come with auto adjuster?
JustDave71
11
06-12-2010 11:08 AM
