primary chain tensioner
I have about 51,000 on my 08 eGlide. I have changed engine oil every 2500 miles and tranny + primary fluid every 5000 miles religiously.
With the number of miles I am starting to think I should look at the primary chain tensioner. Since they took away the inspection cover on the primary cover (not derby) I will have to pull the cover to inspect it... which looks like kind of a big deal to me.
So, other than pulling the cover and looking at the tensioner, is there any way to tell it needs to be replaced by the way the bike shifts or runs? All seems fine, but I'd rather to some maintenance up front rather than repair damage later.
And how big a deal is this project?
Thanks.
Thanks.
It's no big deal to pull the outer primary chain cover. Remove the floorboard support arm from the frame - two bolts. Remove the shifter arm - one pinch bolt. Remove the bolts from the primary cover. Inspect the tensioner. If bad remove two bolts and change it out following the instructions in the service manual. You will need one tie-wrap to hold the tensioner in a compressed position until you bolt it in. At that time you cut the tie-wrap and release the tension.
Replace the cover with new gasket. Torque the bolts down in the pattern shown in the service manual. Replace the shifter arm. Replace the floorboard support arm and torque to service manual specs.
Make sure you clean out the holes in the Allen bolts to make sure they have no compacted dirt in them so the wrench bottoms out in the hole. Otherwise you may round out the flats.
Use blue loctite on the bolts.
It's really no big deal at all. There are different length bolts in some locations so it may be a wise thing to do to get a piece of cardboard and draw the outline of the cover on it and place the bolts in their position as you remove them. Be sure to torque the bolts in the proper sequence and order when replacing them or you can warp the cover. Tbone has you covered on the rest.
The alignment of the sprockets, sharpness of the edges of the chain, and chain tension affect the life of the shoe among other things.
Removing the primary cover on a late model TC takes about 10 minutes including removing the floorboard and heel shifter (draining the fluid will take a few minutes longer assuming you use the drain plug to do so).
FWIW, I'd be careful with the use of any Locktite...the longer bolts can twist and break leaving a real mess.
Do follow the torque sequence for all bolts.
Had the one on my 07 replaced under warranty at 33,000 then again at 51,000. At the 51,000 they also replaced chain and compensator. 87,000 now and just got bike back from more warranty work where they replaced the compensator again, this time with the SE comp and the tensioner looked fine.
rpoteau
09-01-2005 02:17 PM
