Baker DD6
#51
Being I do not have this problem when I put all the stock parts in the primary if there is something that is manufactured wrong it has to be on Bakers end. I have wondered about Baker s compensating sprocket. Problem is I have called Baker a WHOLE lot trying to get the problem fix and they are getting kinda of snotty now!!!!!!! I have WAY to damn much in this for what I am ending up with! For what I have in the DD6 fiasco I could have done my last five states and had money left over. Not only that I have missed a LOT of riding time!!!!!!!!!!!!!!
#52
I wrote an email to Baker with a detailed explaination of the noise from my primary after installing the DD6 in two of the drivelines in my FLH. I also gave them the link to this sight and to this section about the DD6 primary noise in particluar. I was told that there are no issues with the DD6 and they would cause no noises in the primary, They did offer me a good price on the fine tooth adjuster they sell. Like I have stated before I really like my DD6 and am happy with the gear set but kinda disappointed that the primary noise is overshadowing such a fine product.
Sorry for venting guys but being I have been out of a steady job for going on 2 years a $2,000 plus hit hurts that much more. One thing is for sure I do not have this problem with the STOCK HD parts when I install them!
Right now when I have the bike sitting and increases the RPM to around 1,800 to 2,000 it is like some one is wracking the primary with a wrench.
#53
The new 07 and up primaries have a great big front sproket that causes the chain to run close to the cover on the front and front bottom.
The slack is thrown down, especially ar lower RPM's, and when I first got my bike it was hitting the first bolt boss down there as it came around.
The factory had even cut a bevel there but it was still kissing. Sounder like a little hammer.
I growned the bevel more and that stopped.
Just something.
Just something.
#54
Having put about 100 miles on the new driveline and readjusted this,that and the other thing, it, the primary seems to have quited down somewhat. I'm not saying it's perfect but livable. I let a friend try it and did not discuss the primary noise and he did comment on it saying he could hear a noise.
#55
#57
#58
#60
DD6 old thread... Resolution?
Was the cause ever isolated? I have a DD6 in my 94 FLSTF and thought my compensator was making noise so opened everything up. I didn't realize I had the 28T sprocket and had purchased at 25T no way that was going in without a chain change.
I did figure out where my noise is coming from. The chain is contacting the inner primary where the front dowel is. I too tightened the adjuster but it makes everything too tight. I am going to clearance the inner primary to fix the problem. It seems that the 28T is just a bit too big. Unfortunately I can only work on my bike in the parking lot and we have a couple hurricanes coming so it will be a couple weeks.
Probably doesn't matter since this thread is 4 years old anyway.
Roy
QUOTE=46u;8129719]BIG difference between the OD6 and the DD6! The DD6 is the same in 6th gear as as stock 5th 1 to 1 and the OD6 is a true over drive. I agree unless you have a really power full motor the OD6 is WAY to much. I paid less then $2K for my DD6 NEW. I will agree after running one I would not recommend the investment but since I have it now I will get it where it makes me happy.
I do not have a problem with transmission noise just primary noise as it has helical cut 4th, 5th and 6th. Even Harley on their 6 speeds had problems with noise before going to helical cut gears.
Thanks[/QUOTE]
Roy
Thanks[/QUOTE]
