Compensator Nut
Hardwood Huh? My wife HAD one of those white nylon cutting boards in the kitchen. I cut it up and made a stepped block for the job. It's still in my tool box. She found out about a week or two later and was all good with it. I think I still have her turkey baster and a few other things still out in the garage she doesn't know about.
Yeah, wood. I thought about going with something like a cutting board material but I was worried about breaking off one of the gear teeth. The second block I made had thicker steps and did the job fine for the last 15-20 degrees of torque. I'm hoping the weather idiots are wrong about rain all week so I take it out and give her a whirl. I sure hope this remedies the knocking noise issue. I'm thinking it will, between it happening often enough for the MOCO to issue a service bulletin and the fact I have gone over everything else. I'll be posting the results as soon as I can get it out put it through the gears. Thanks again for all the help and advice.
I wasn't sure when the noise got louder (I could only hear it at low idle) so went to the custom shop and had their mech listen to it - he and another guy said the Comp right off and that was the first thing I should check. If that wasn't it, the cam chain would be the second choice. I had thought it was a bottom end bearing from the sound.
Imagine my relief!
I made a sprocket stop from a length of flat metal, but you guys had a better one, being soft. I won't use that piece again.
Imagine my relief!
Looking for a little quick help here. I have all the tools and the new torquing procedure, along with the telltale knocking. I have gone over her with a fine tooth and found nothing loose and I have adjusted the clutch so I'm down ot the comp. nut. It's an 04 EGC. here is my question, Do you have to pull everything out i.e. the clutch basket and remove the primary chain etc. or do you/can you simply pull the nut and clean the threads, apply the red loctite and re-torque per the new procedure? Any help and/or insight is GREATLY appreciated!
I've only check tq once. Put wrench on and if it moved, if I remember correct. Usually I am taking whole thing off for other reasons
CGreasamar
04-02-2012 06:28 PM
rkcmike63
01-25-2010 04:39 AM
