Primary/Transmission/Driveline/Clutch Find answers to general powertrain, primary and transmission. Have clutch issues and need suggestions? Post them here.
See through inspection cover??
Old 11-15-2006, 05:43 PM
hogwyld79's Avatar
hogwyld79
hogwyld79 is offline
Default See through inspection cover??
I have an EVO motor that I want to put a see through primary inspection cover on. Has anyone out there made one up already? If so, what kind of material did you use? I am thinking about using lexan or plexiglass, but I'm not sure if it will withstand the temps of the primary lube once it gets hot. Any help or thoughts would be appreciated. I would also like to do the derby cover but I'm not sure if the contours of it will allow it.
Phil
Old 11-15-2006, 06:18 PM
NitroBerserker's Avatar
NitroBerserker
NitroBerserker is offline
Default RE: See through inspection cover??
I don't know about the inspection cover but check here > AIM Tamachi VPC for a clear derby cover, might beat making one. Personally I think it looks funny becauce the clutch drum is not centered. JMHO
Old 11-16-2006, 03:21 AM
hogwyld79's Avatar
hogwyld79
I'd have to agree with you on the funny looking part. It almost looks like something's broken. Thanks for the site.
Phil
santajim
2014-2023 Touring Models
30
09-29-2015 11:31 PM
brucepancake
09-30-2014 09:44 PM
Joe What
05-23-2012 05:34 PM
BobbyC
06-09-2007 01:32 PM
anubisss
10-21-2006 10:37 PM
Quick Reply: See through inspection cover??
