Diaphram Spring Pressure?
Hello,
I have my primary apart on my 2007 Ultra Classic Screaming Eagle to do some housekeeping work.
While under the cover I was interested in installing the SE clutch spring. I have tried to find out the pressure on my stock spring just to make sure I wasn't going lighter on spring pressure. I thought the SE spring would be stronger. Some folks on the forums say that the CVO bikes already have the SE spring, but I don't believe so.
Anyway I purchased the SE spring and placed them side by side. The spring thickness appears the same. I have not verified that with a micrometer as of yet. What I did notice is that there is a lot less spring material present. Note how much furher the spring notches are cut away between the fingers of the spring. The SE spring is on top of the stock spring in the photo. Stock spring has the pink square and white dot.
I know this is not a valid method for testing, but when placed on a table and depressing a finger or two on the clutch springs the SE springs appears much weaker than my stock spring.
Any thoughts or ideas?
I'm sure you've seen this table before and it probably does nothing to help answer your question, but thought I'd throw it out there.
37882-06 117KgF 2006-88”, 2007 thru 2010-96” Redish Brown Square / Yellow Dot
37871-04 135KgF 2004-05 88” and 2010 Limited Yellow Dot / Yellow Stripe
37871-98A 145KgF 1998-2003 Yellow Dot
37807-03 165KgF 2007 thru 2010-103 ”Police" Yellow Dot / Pink Dot
37951-98 175KgF Current SE Nothing
Carbo
03-03-2013 06:40 AM
1931jamesw
05-19-2010 08:18 PM
lickmstickmman
04-02-2007 05:37 PM
lickmstickmman
03-31-2007 01:04 PM
