Primary/Transmission/Driveline/Clutch Find answers to general powertrain, primary and transmission. Have clutch issues and need suggestions? Post them here.
Need Help on a Clutch issue
Old 04-29-2012, 08:41 AM
first dyna 07's Avatar
first dyna 07
first dyna 07 is offline
Default Need Help on a Clutch issue
2007 FXD 16,000 miles on her . The first time i ever adjusted the clutch from the primary . I all ways did it from the cable the adjusting So now here i my issue when the bike first starts off everything is fine it shift fine it goes in an out of gear fine . But once it gets HOT like if iam in traffic the bike freaks out . My clutch goes away like I did not have any hard to shift up or down hard to get out of gear When it cools down if is fine HELP it is driven me crazy
Phil
Old 04-30-2012, 01:40 PM
doc ock's Avatar
doc ock
doc ock is offline
I would start over. Take out the adjustment in the cable, make it loose. Then readjust the clutch itself. Adjusting the cable last. Also check the primary chain it too needs adjusted.
Old 04-30-2012, 04:21 PM
nvsteve's Avatar
nvsteve
nvsteve is offline
Correct, sounds like maybe he missed a step or did something out of sequence. He's got an 07 so it has auto primary chain adjust.
imjwag
08-01-2015 07:33 PM
72monte
Shovelhead
04-04-2013 09:23 PM
gavdar
09-01-2012 04:22 AM
Ace2000
06-20-2009 08:06 PM
gunnert
03-04-2007 09:43 PM
Quick Reply: Need Help on a Clutch issue
