Primary/Transmission/Driveline/Clutch Find answers to general powertrain, primary and transmission. Have clutch issues and need suggestions? Post them here.
Inner Primary bearing change ?
Old 07-06-2012, 07:06 AM
FroggyFatBoy's Avatar
FroggyFatBoy
FroggyFatBoy is offline
just to finalize the job.. i had to cut off the sleeve with dremel since all of my pullers were to wide to get in behind the sleeve with the trans sprocket in place. it popped with no problems with a cut into the sleeve about 75% of the thickness.
the SKF bearing wasn't hard to find but the seal was another story. i deal with a couple of different auto parts company's and neither could cross over the 25x52x7 number. napa told me that their short seal number that i gave them was a good number, but it wasn't coming up in the system and they couldn't figure out why or how to order them. ok.. I called a company i deal with on hard to find brgs and seals and they crossed it over to SKF number. the seal fit like a glove, but the brg was another issue.. i had to use a old style brake hone with emory cloth wrapped on it to take enough material out of the inner brg race's inside diameter for it to have a smooth slide on installation.. wasn't bad, just took some time. i also removed the bearings end seals/shields. i figured i wanted oil to get in and out and not be trapped between the brg and seal possibly causing a leak. I've had her out on two different runs, one about 15 and the other 30 miles, and all appears dry..
part numbers.. SKF on both..
Brg- 6205-2ZJ
Seal- 692325
Thanks Soft..
If anyone ever needs a odd bearing or seal for just about anything in the mechanical world, cars, boats, washing machines, lawn mowers etc.. if you have a imprinted number off the seal, brg or exact dimensions, they can find it for you.
http://www.applied.com/
  #42
Old 07-15-2012, 07:39 PM
PKellyMc's Avatar
PKellyMc
PKellyMc is offline
Location: PacNW; Beacon of Conservatism in a Sea of Liberals.......AZ Snowbird; Just another Conservative
Question Baker Bearing; leave sealed?
Jumping in late on this one, but I find myself inside my IP for a belt change, and rotor/stator upgrade. I'm also installing the Baker while inside and this presents a question; Should I leave the bearing sealed, or pop the covers and open the inside to continuous lubrication?...Mark@ Baker Drivetrain??
  #43
Old 07-16-2012, 01:00 PM
M&P340's Avatar
M&P340
M&P340 is offline
Mark must be busy.
I asked him this question some time back. See his response here in post #6.
I went with the All ***** double-row bearing upgrade, and I removed both side seals to maximize oil throughput to my ***** . 2000 mi on it so far, & smooth as glass.
  #44
Old 07-16-2012, 02:10 PM
corliss@bakerdrivetrain.com's Avatar
corliss@bakerdrivetrain.com is offline
Received 1,856 Likes on 1,287 Posts
I removed the shield on bearing as well.
  #45
Old 07-16-2012, 02:43 PM
soft 02's Avatar
soft 02
soft 02 is offline
Received 4,570 Likes on 2,888 Posts
I did not as I didnt want normal primary debris to get in there but thats just me.
  #46
Old 07-17-2012, 06:45 PM
FroggyFatBoy
I pulled the shields off the bearing.. i wanted fluid to be able to get in AND out with no problems. i felt with the shields in, fluid could get trapped between bearing and seal and may force fluid out.. also by removing the shields it lets fluid continuously flow through the bearing and not allow any type of debris to get trapped inside...
  #47
Old 05-27-2015, 04:00 PM
wstevens29's Avatar
wstevens29
wstevens29 is offline
Stage II
I know it's old thread, How well is the "napa" bearing holding up after some miles?
  #48
Old 06-07-2015, 05:57 AM
FroggyFatBoy
3yrs and without looking at maintenance log book I would guess about 15k miles..
no leaks, no noises.. well unusual noises..
teeroy_
13
11-04-2020 05:30 PM
clarkchriston
10-26-2020 11:04 AM
1987 FLHS
02-06-2014 09:26 AM
M&P340
15
06-24-2012 08:30 PM
scottdoege
10-23-2011 08:48 AM
Quick Reply: Inner Primary bearing change ?
