Primary/Transmission/Driveline/Clutch Find answers to general powertrain, primary and transmission. Have clutch issues and need suggestions? Post them here.
HARD SHIFTING!!
Old 08-05-2005, 04:52 AM
JOEY5632187's Avatar
JOEY5632187
JOEY5632187 is offline
1st Gear
Default HARD SHIFTING!!
I just picked up an 86 softail last month, and not sure if whats happening is normal. It shifts up fine, but downshifts very hard. If I wait until Im going 5-10mph, it downshifts no problem, but any faster I almost have to force it to downshift. Also, it wont go into neutral unless I shut it off, or just about to stop. Is this normal, and if not, what could be the problem?
Old 08-05-2005, 09:00 AM
JBBOOKS's Avatar
JBBOOKS
JBBOOKS is offline
Default RE: HARD SHIFTING!!
Checking the primary chain and clutch adjustments are the first two things that come to mind. I'm sure others will have more insight for you shortly.
Good luck.
Old 08-05-2005, 09:12 AM
HDF Tech's Avatar
HDF Tech
HDF Tech is offline
I would say the clutch needs an adjustment from what you say. Has all the classic symptoms.
Old 08-05-2005, 01:08 PM
skywagon's Avatar
skywagon
skywagon is offline
Throw in a VPC, run all adjustments and smile all the way to town lol.[sm=closed.gif]
Old 08-05-2005, 02:07 PM
HDWRENCH's Avatar
HDWRENCH
HDWRENCH is offline
Sounds like the clutch is out of adjustment. Buy a service manual follow the steps, they are a must have item. I also like to use Bel ray syn trans fluid as it works great , and Amsoil in the primary with those items I have found to work the best they help with clutch life on big inch motors and the bel ray ( imop) has the best shifting quality of all the syn products I have tried. . Lube the cable when you do the adjustment as well. other than that have fun working on your scoot.
Old 08-06-2005, 02:01 AM
mikeisglidn's Avatar
mikeisglidn
mikeisglidn is offline
another symtom of a mis adjusted clutch is when you have it in gear and hit the starter button it will try to creep forward on ya. good luck let us know what you find!!
Old 08-06-2005, 02:03 AM
HDF Tech's Avatar
HDF Tech
HDF Tech is offline
Hey Mike, now that's technical there
Old 08-06-2005, 02:14 AM
stangnut's Avatar
stangnut
stangnut is offline
I had a hell of time finding neutral when I first got my Dyna, but after changin to synthetic (Royal Purple for me...) it is amazing at the difference it made.... I never really had problems shifting, just finding neutral.... If the bike tries to move when pushing starter button while clutch is in, that would indicate adj is needed, if not I would say clutch is okay....
Rich
Old 08-06-2005, 09:43 AM
HDF Tech's Avatar
HDF Tech
HDF Tech is offline
ORIGINAL: mikeisglidn
I would think that if it was in gear and you hit the starter button that it would do a bit more than creep foward on you , I hope you mean with the clutch pulled in
Old 08-07-2005, 12:35 AM
mikeisglidn
sorry boys i have a cop bike and it wont start with out the clutch pulled in!!
Quick Reply: HARD SHIFTING!!
