Can't hit neutral
Can't hit neutral
I have an 06 Deuce with a Barnett Scorpion clutch with 1500 miles on it. I can’t find neutral with the motor running, so I installed Redline V-Twin Primary in the primary and Redline Heavy Shockproof in the tranny. Still can’t find neutral. My question is, if this is lubricant related and not adjustment related, would the problem more likely be in the primary or the tranny?
Your problem sounds like your clutch is slightly out of adjustment and that is easy to fix. The plates steadily wear over time, so you can expect to adjust your clutch occasionally.
Thanks grbrown. I had the clutch installed 1500 miles ago and from day one haven't been able to get it into neutral. In reading through the forums I found that several people had the same problem and made the situation better by changing the fluids, so I started there. If the clutch is out of adjustment, it has been so since I picked it up from the dealer and I have a lot of faith in that dealer. I drive 300 miles one-way to have him work on my bike. I do have a manual and will check the clutch adjustment. Thanks for you help.
Velocity1
07-28-2013 08:35 AM
