80 Sporty xlh transmission problem...
so I put the bike in first and let out the clutch. the bike gives out a horrible grinding noise, lurches as it is moving, second on up doesnt engage, and the bike "catches' and gives me intermitent resistance as tho the clutch is out (when in fact it is in) when i roll it back and forth. a buddy says there is something inside the case that is rattling around catching in the gears, and that it is probably a gear tooth from the transmission since it's all jacked up. what do you think?
ml crisis
12-27-2012 05:14 PM
tpatrickchoppers
11-28-2006 10:40 PM
