shifting spring
I've only done one, it took the best part of 8 hrs. It is the last part to come out and the first to go in!! There is a hell of a lot of parts to and gaskets, oils etc to be r&r between. The job requires special sockets etc to remove the pulleys etc.
If you can't do the work yourself, find an independant locally, their labor rates will or should be substantially less than a dealer. Fastrider124
TexasScott
Milwaukee Eight (M8)
11
07-08-2019 07:49 PM
