1979 Shovelhead 5 spd in 4 spd case
Have a aftermarket 5 speed in a 4 speed case . Noticed some winding noise so I pulled it apart I did notice some issues with the clutch 1 stud was loose and last fiber plate was gummed up also roller bearings on hub seem a little loose but what I'm really concerned with is this I have the back wheel off the ground and it spins freely in neutral but when I turn the main shaft there's some clanky noise from trans and the rear wheel moves just a tiny bit in either direction. thought there were some clutch problems ! Down the road it shifts fine in every gear and hits neutral when you want it!
yuandp
14
07-03-2014 05:44 AM
