Finger loose!
Finger loose!
This is my first post on this site, but let me thank everyone for all the info I've already found on here! I'm elbow deep in grease, tearing into the primary/mainshaft leak I inherited with my 99 road king police, 50,000 miles. I think I've got a good handle on what this project entails thanks to this forum. Today I went out to the shop to finally try taking the belt pulley nut off. When I was loosening the two lock plate screws I noticed the mainshaft nut wiggling. I thought, "no way in hell". Sure enough, I got the lock plate off and was able to take the mainshaft nut off with my fingers. Yeah, I know you are all jealous I didn't have to use a 5 foot cheater pipe. I then pulled the spacer out and noticed the back face of the spacer was worn really bad with a bur on the back edge. Is this normal? I am guessing the wear is what caused the nut to be loose... I am planning on replacing the spacer, quad seal, main seal and 5th gear seal. Will that be enough, or is the excessive wear on the back of the spacer an indication of a bigger problem? Anyone else ever run into this?
Check out your main bearing and make sure it did not get beat up too bad. Your spacer did not cause your nut to come loose but I can see your nut being loose as the cause of your spacer having odd wear. Also make sure the threads on your main drive gear are in tact by screwing the nut on all the way with the pulley off.Check the splines on your pulley as well if it was loose they may have gotten chewed up.
Not common if it was done right originally. Clean the nut with lacquer thin as well as the threads on the main drive gear. Apply red loctite to the nut and the torque spec is 80 foot plus 30 degrees or.......do what we do hit the f@#ker with an impact gun you will nut hurt the main drive gear and it will make sure it is tight.
Flhfxd
07-16-2011 07:00 AM
