Primary/Transmission/Driveline/Clutch Find answers to general powertrain, primary and transmission. Have clutch issues and need suggestions? Post them here.
shifting gears
Old 01-20-2013, 10:03 AM
shovelmonster67's Avatar
shovelmonster67
shovelmonster67 is offline
Stage I
Default shifting gears
Ihave a 1980 fxsb that has a 103" shovel and rotary top trans. i had the trans repaired last summer and when i put it back in the bike,I found that shifting from first to second it did not hit any detent or stop and the shifter went way to far, the linkage got jammed against the trans case.
Is this problem linkage inside the rotary top, or is the linkage on the side worn or misaligned ? any one know?
Old 01-20-2013, 01:20 PM
WindJammer's Avatar
WindJammer
WindJammer is offline
Twin Cam engine transmissions have a shift drum that moves the shift forks that select the respective gear. When the shift drum is turned by depressing the shift lever, a detent holds the shift drum in position. If the transmissions are similar I'd say the detent isn't working. The key is that you CAN select gears so the selector is working, as is the shift drum and forks.
Old 01-20-2013, 07:46 PM
Hillsidecycle.com's Avatar
Hillsidecycle.com
Hillsidecycle.com is offline
Sponsor
Are you sure the shift forks are installed correctly??
Also, the shift clutches(shift dogs as some call them) could also be installed incorrectly.
Those gearboxes are very easy to address.
We used a highly modified version of one to help our 108" AHDRA Modified Class bike, run a ton of 8.90's.
__________________
HILLSIDE MOTORCYCLE & MACHINE, INC.
HARLEY-DAVIDSON SPEED & SERVICE CENTER
5225 SOUTH MAIN ST., MUNNSVILLE, N.Y. 13409
Sales/Support 315-495-6650
www.hillsidecycle.com
Walk-in Retail Showroom
Complete H-D Machine Shop
Case & cylinder boring
Complete Cylinder Head Shop
High-Performance Engine Kits
Crank Rebuilding
Direct Link & PowerVision Tuning
Goodson HD Tooling Manufacturer
Maxton Mile World Record
4500 sq ft. facility
OVER 35 YEARS OF H-D ENGINE BUILDING.
See us on Facebook.
Old 01-21-2013, 07:34 AM
Dan89FLSTC's Avatar
Dan89FLSTC
Dan89FLSTC is offline
Received 8,499 Likes on 4,612 Posts
Originally Posted by WindJammer
Twin Cam engine transmissions have a shift drum...
The op is asking about a 4 speed transmission...
The transmissions are completely different.
Off Topic Note: not all twin cam transmissions are the same, there are 5 speed and two versions of the 6 speed. Some 5 speeds have the shift detent on the drum, but some do not.
Old 01-21-2013, 12:56 PM
corliss@bakerdrivetrain.com's Avatar
corliss@bakerdrivetrain.com is offline
Received 1,856 Likes on 1,287 Posts
4 speed shifting has a lot more (about triple) the throw (amount your foot has to travel to shift gears) of a 5 speed or later transmission.
Old 01-22-2013, 03:50 PM
46u's Avatar
46u
46u is offline
On the late 4 speeds the paw carrier wears quick. All I have built in the last 10 years had to have this part replaced. Another of HDs not so bright ideas.
Next In Line
04-07-2015 04:51 PM
bonesmutley
Shovelhead
08-12-2013 11:34 AM
Pondskipper
10-17-2012 09:32 AM
vince.rogers@walgreens.com
01-15-2012 09:37 AM
Radioman_cut
04-20-2011 07:53 PM
Quick Reply: shifting gears
